Darkwing Duc Inviato 6 Agosto Inviato 6 Agosto Geetings from a danish Ducatista trying to fix Ducati Monster 1100 with Continental M3C ECU.
Darkwing Duc Inviato 6 Agosto Autore Inviato 6 Agosto Hi Admin, I am working on my new to me Ducati Monster 1100S with Continental M3C ECU. Now I bought a I/O Terminal with the Motorcycle program for Ducati's with M3C. The bike has a Termi Racing exhaust and ECU with 83IU1MOB program. I bought a used standard ECU with 84IU1MIL program in order to make the bike street legal. I have read both ECU's flash memory and got 256kB files that seem ok. I also read the Eeprom memory but got 2kB files with only FF in complete file. Same for both ECU's. My hope is to find a way to make it work on my bike with immobilizer. Do I need to virginize the Ecu?
ADMIN Inviato 7 Agosto Inviato 7 Agosto If your goal is to make the new ECU work for your vehicle, then read the complete contents (flash + EEPROM) of the working ECU and write them to the new ECU. You must therefore perform a complete backup; the two ECUs must be identical. This way, your vehicle will work with both ECUs. There is no need to remove the immobilizer code in this case.
Darkwing Duc Inviato 11 Agosto Autore Inviato 11 Agosto I actually found that there is no immobilizer in this ecu. I just mounted it on bike and it started right up. All Immo is handled by dashboard . So now bike is running completely std except KN ( race ) air-filter. I have a follow up question regarding DP map. I posted it in: File remapping discussions/Motorcycle
