Darkwing Duc Inviato 11 Agosto Inviato 11 Agosto Hello. Bought my bike ( M1100S - 2009 ) with Termignoni race slip-on's and race-ECU. I want to make it street legal. I live in Denmark, so EU map. I learned that years ago you could buy a DP set with Homologated Titanium Cans and KN filter plus a special Homologated map. This map were a bit less lean than stock, but still street legal. I am looking for this map. Does anyone know what it is called? ECU: Continental M3C Ducati number: 286.4.170.2A My oem map is: Hardware no.: S180037007Z9 Software no.: D084IU1MIL ECU Label says: M1100 D084IU1MIL vs.EUROPA DUCATI060 I had no luck finding valid info wit Google. So if you own this DP/Termi set? or just know what this map is called? 🙏 Any help is much appreciated.
ADMIN Inviato 11 Agosto Inviato 11 Agosto You want to increase or decrease power, what do you mean by “legal”?
Darkwing Duc Inviato 11 Agosto Autore Inviato 11 Agosto It is Homologated meaning it is street legal and noise and emissions are below the legal threshold. It keeps flapper valve and lambda's intact ( closed loop ). The complete set was sold as a fully legal upgrade, that improved the sound and made it run smoother at low revs. I expect they just go closer to the thresholds...
ADMIN Inviato 12 Agosto Inviato 12 Agosto I don't have much information on this; to start, you should try purchasing the original file, either for the same firmware version or for one where you're sure it's the one you're looking for. Once you find it, you can copy the changes to your firmware version.
