ho questo errori ki mi spiega cosa sono
Ospite stabia83
audi 3 140 cv tdi errori sono
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
nel dettaglio
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBL
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023174
Shop #: WSC 06435
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermitten
Address 09: Cent. Elect. Labels: 8P0-907-279.LBL
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H34 0301
Coding: 03884F029214100000160000160000000000FE0F5C
Shop #: WSC 00000
Part No: 1K1 955 119 A
Component: Wischer VW350 011 0301
Coding: 00065493
Shop #: WSC 00000
3 Faults Found:
004 - No Signal/Communication - Intermittent
02498 - Left Low Beam Reflector Motor (V294)
012 - Electrical Fault in Circuit
02499 - Right Low Beam Reflector Motor (V295)
Address 19: CAN Gateway Labels: 1K0-907-530.LBL
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Coding: 3D3F0B00072102
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 8
Reset counter: 65
Mileage: 85274 km
Time Indication: 0
Date: 2009.10.25
Time: 22:19:54
Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.10 1401
1 Fault Found:
Freeze Frame:
Mileage: 5240 km
Temperature: 20.0°C
Voltage: 12.50 V
Voltage: 12.30 V
grazie ki spiega ke errori sono ?..
Dove c'è scritto STATUS OK...non sono errori.
Gli errori sono dove hai MALFUNCTION :lol:
Ospite stabia83
ora controllo su quel sito cmq l'avevo capito ke status ok era tutto apposto vi ringrazio...vi faccio sapere puo servire a qualcun'altro...
Ospite stabia83
sono andato sul sito ma nn mi fa la traduzione di quelle parole...boo
Ospite stabia83
e dove si trova? hiihihi cmq grazie della risposta nn so qual'e ti sarei tanto grado di dirmi dove si trova....grazieee
Ospite stabia83
come faccio a vedere se il rele e buono e cmq nn ho capito dove si trova ?
Ospite stabia83
qualcosa ne capisco di elettronica ...si puo vedere se un rele e buono ho cpito dove stanno l'avro smontato 20 30 volte il pezzo sotto lo sterzo ....x fare l'impianto ecc... come si fa a vedere se funziona il rele?ti ringrazio
Codice VAG 01314 -Centralina di controlo motore,sistema di programatore velocita di crociera -funzionamento difettoso. Causa probabile-Centralina di controlo motore. O forse rimapata?????vedi tu.
Ospite marins
si l'auto e rimappata il cruise control nn lo tengo....e qualke centralina piccola da cambiare?ciao e grazie
pensa ke dopo la riprogrammazione seriale su queste auto vengono memorizzati sempre gli errori sulla centralina 1 e 3 per mancata comunicazione quindi resetta e vedi ke non te li darà +
  • 4 mesi dopo...
secondo me relè e pedale freno non sono, anche perchè se fossero, lo dice con altri due specifici errori.è più probabile fossero li dalla riprogrammazione quegli errori...o hanno abilitato il cruiser ma mancando levetta e tutto ilresto...da errore per forza....
  • 2 anni dopo...
Ospite stabia83
Coding: 0023174
Shop #: WSC 06435
1 Fault Found:
ho capito na che mi si accende la spia esp dopo 10 minuti sempre dopo 10 minuti ache se sto fermo 10 minuti in parcheggio per questo errore perche quando mi esce a spia accesa se cancello questo errore si spegne la spia cosa puo essere grazie
