Eliminazione Egr Panda 1.3 mj con Ads Egr Remover + Mpps v12
Buongiorno ragazzi, volevo sapere se era possibile leggere  e scrivere la centralina della Fiat panda 1.3 mj del 2004 (quella senza fap) con Mpps v.12 e se era possibile rimuovere l'egr con il software Egr Remover.
Queste sono le centraline auto che mi elenca il programma
-------------------------------------------------------------- (Isuzu models supported to : NRP300,NRP500, Canter,NR400, NNR200, EFI, Dmax, Truck) - Adblue VAG EDC17CP24 has been improved - Adblue - DAF PC3 has been improved for new models. - Adblue EDC17CP20 improved for Passat models. - Adblue EDC17CP20 more improved - Alfa EDC16C39 Solution 2 improved for some file types. - Audi - VW EDC17CP04 improved for new models. - Audi - VW EDC16U31 4x switch type file signs added - Audi - VW EDC16U31 Switch solution added - Audi - VW EDC16U34 P0545 and P0546 DTC automatic removing added - Audi - VW EDC17C46 signs more improved - Audi - VW EDC17C46 signs more improved - Audi - VW EDC17CP04 Flap removing added - Audi - VW EDC17CP04 solution has been improved - Audi - VW EDC17CP20 Flap solution has been added - Audi EDC16CP34-4 revized fixed. - Audi EDC16CP34-4 solution revised with new. - Audi EDC17CP04 2th switch added - Audi EDC17CP14 has improved for support to Q5 models. - Audi EDC17CP44 switch fixed for Audi car. - Audi EDC17CP54 added - Audi PCR2.1 regeneration switch alternate added - Audi PPD1.x new solution added - BMW 1mb Type1 solution added 525 models. - BMW EDC16C35 supported to all types (Generic) - BMW EDC16C35-2 item added DDE7 support - BMW EDC17C41 added - BMW EDC17C56 solution added - BMW EDC17CP06 DTC Root + DTCx80 removing added - BMW EDC17CP45 ASC solution added - BMW Mini EDC15C35 bug fixed. - Chevrolet DCM3.7 improved, DTC structure fixed - Chevrolet Delphi DCM3.7 acceleration problem fixed - Chevrolet EDC16C39 added - Chevrolet EDC16C39 has been improved - Chevrolet EDC16C39 improved - Chrysler EDC16C31 added alternate solution - Chrysler EDC16CP31 solution improved - Citroen - Peugeot EDC17C10 added more DTCs - Citroen - Peugeot EDC17C10 Additive Pump removing improved - Citroen Berlingo EDC17C10 added - Citroen Delphi DCM3.5 Type2 added in main solution - Citroen EDC17C10 solution Picasso model support added - Citroen SID803A supported with Peugeot SID803A solution now - Citroen SID807 EGR + DPF added - Citroen SID807 sign are improved - Dacia Delphi DCM3.4 solution has been added - Dacia Delphi DCM3.4 solution has been added. - Dacia section added with EDC17CP42 ECU. - Denso map8 problem fixed - Dodge EDC16U31 solution has been added - EDC17CP02 - CP06 New DTC's added - EDC17CP14 Flap removing has been improved for different models. - EDC17CP14 solution improved - EDC17CP24 bug fixed Tamarrov - Fiat 6F3 Generic added Fiat500 models - Fiat 8F2 signs are improved, - Fiat 8F3 solution fixed - Fiat 8F3 solution Improved - Fiat 8F3 solution Improved - Fiat Doblo 6Fx improved for other models - Fiat Ducato type more improved - Fiat EDC16C39 Generic improved for Chrome models. - Fiat Grande Punto 8F2 improved to other models - Fiat Marelli 6F3 solution automatic EGR disable function removed. - Fiat Marelli 8F3 Generic P1564 DTC removing has been added - Fiat Marelli 8F3 solution added - File control : CMD, Kess formats and blank file controlling added. - Fixed 62 signs problems reported by customers. - Fixed some Flap items was showing DPF removing message. - Flap EDC16C34 EDC16CP34 revised - Flap EDC16U1 Golf5 new sign added - Flap EDC17CP14 Audi different type sign added - Flap EDC17CP14 Audi different type sign added - Ford 9M51 type solution item added - Ford DCM3.5 Type2 solution(983kb) has been improved for Mondeo models - Ford Connect Solution new DTCs added for removing - Ford Delphi DCM3.2 solution has been added. - Ford Delphi DCM3.5 Improved for other models. - Ford Delphi DCM35 P2463 and P246b DTC removing added - Ford EDC16C3.9.18 added - Ford EDC16C34 Additive removing added - Ford EDC16C34 improved for Cmax models - Ford EDC16C34 switch P2484 2th DTC added - Ford EDC17C10 solution has been added - Ford Focus EDC16C34 Switch solution new signs added - Ford Mondeo Delphi DCM3.5 type ECU solution added - Ford Sid206 Generic improved for Mondeo model - Ford SID206 Generic solution improved for modified files. - Ford SID206 Kuga renew solution tested with - Ford SID208 EGR + DPF added - Ford SID208 P244D DTC removing added - Ford SID208 Transit and Ranger models supports improved - Ford SID803A new solution added - Ford Transit Connect Type solution added new DTCs - Ford Transit Connect Type solution added new DTCs - Ford, Citroen, Peugeot, Volvo EDC16C34 switch solustion - Generic EDC16 - EDC17 Switch search improved with new add switch solutions - Golf5 EDC16U1 Flap added - Honda Civic solution improved for different ECU soft versions. - Honda EDC16C31 solution improved - Honda EDC17CP06 has been improved - Honda EDC17CP16 switch solution added - Honda EDC17CP16 switch solution added - Hyundai - KIA EDC16C39 Switch solution added - Hyundai / KIA EDC17C08 Double DPF switch problem fixed - Hyundai EDC16C39 Generic improved for Tucson models. - Hyundai Generic Switch solution new DTC's added - Hyundai SantaFe solution added - In Toyota Denso solution added Prado VX model support. - Isuzu Transtoron NR400 Model EGR + DPF support added - Isuzu Transtron Dmax added - Isuzu Transtron EFI, Canter, NLP models solution added - Isuzu Transtron improved for Dmax Type2 models. - Isuzu Transtron NNR200 model support added - Isuzu Transtron P2002 P0401 automatic DTC removing has been added - Italian language text has been revised - Italian Language totally revised, now more good - Iveco EDC17CP52 more DTCs removing has been added - Iveco EDC17CP52 solution added (EGR + DPF) - Jaguar EDC17CP11 added - Jaguar EDC17CP11 fixed some DTC's - Jaguar SID204 fixed, improved for added models. - Jaguar SID204 reported P0000 problem fixed - Jaguar SID204 solution has been improved - Jeep and Dodge EDC17C79 switch solution has been added - Jeep EDC16CP31 DTC removing improved. - Jeep EDC16U1 added new automatic switch solution - Jeep EDC16U1 added new automatic switch solution - Jeep EDC17C79 added - Jeep Grand Cheroke EDC16CP31 added - KIA Carens 5th search point fixed - KIA EDC17C08 solution has been improved. - KIA EDC17C08 Switch added - Lancia 6f3 Solution added - Lancia 8F3 solution improved - Lancia EDC16C39 added - LandRover Sid208 added - M55 solution improved for 1mb files. - Mazda 3 Denso models P2584 P2585 DTC removing added - Mazda CX7 Adblue + DPF more improved - Mazda CX7 Adblue remove added - Mazda Denso Partial DTC added - Mazda EDC16C34 revised. - Mazda EDC16C34 Switch solution added - MB EDC16C31 2011+ solusyon improved for MB Vivano models. - MB EDC17C10 Switch added, DTC's improved - MB Flap M55 improved. - Mercedes EDC17C01 - CP01 switch solution has been added - Mercedes 2011+ solution restored again. - Mercedes DCM3.5 4MB Type2 solution added - Mercedes DCM3.5 solution DTC P244A added - Mercedes DCM3.5 Type1 solution improved, added new DTC's. - Mercedes DCM3.5 Type2 DTC section totally revized - Mercedes DCM35 CRD Type2 4MB P2454 DTC removing added - Mercedes Delphi DCM3.5 CRD2 Type1 solution added P2279 automatic removing - Mercedes Delphi DCM35 Type1 P0475 automatic removing added - Mercedes EDC16C31 - CP31 item improved for MB CLS Models - Mercedes EDC16C31 1mb Type1 solution improved for W211 models - Mercedes EDC16C31 Type2 Generic solution improved - Mercedes EDC16CP31 solution improved for ML models - Mercedes EDC16CP31 solution improved for ML models - Mercedes EDC16CP36 solution revized - Mercedes EDC16CP36 Type1 solution 2 new signs added - Mercedes EDC17CP10 solution improved. - Mercedes EDC17CP10 solution revized - Mercedes EDC17CP46 solution improved - Mercedes ML EDC16C31 support has been improved - Mercedes Sprinter EDC17CP46 switch solution added - Mercedes Sprinter EDC17CP46 switch solution added - Mitsubishi Denso 2th solution added for compatible other some models. - Mitsubishi Denso has been improved - Mitsubishi EDC16CP39 Switch solution has been added - Mitsubishi EDC17CP15 DPF + EGR solution has been added - Mitsubishi EDC17CP15 has been improved - Nissan EDC16CP33 Type2 solution has been improved for more new models. - Nissan EDC17C42 opening problem has been fixed - Nissan SID305 P1525 fixed, improved - Opel - Vauxhall OpelEDC17C59 Switch solution added - Opel EDC17C59 improved. - Opel Astra J special solution added - Opel Astra J special solution added - Opel Denso Partial DTC solution improved - Opel Denso solution improved for DTC, light problems - Opel EDC16C39 Antara added in main solution. - Opel EDC16C9 EGR + DPF 1x P1901 DTC fixed. - Opel EDC16C9 EGR + DPF 1x P1901 DTC fixed. - Opel EDC17C18 - 19 revized - Opel EDC17C18 Corsa D files signs has been added. - Opel EDC17C18 improved - Opel EDC17C18 some DTC problems fixed - Opel EDC17C18-19 solution improved - Opel EDC17C18-19 solution improved for Vauxhall EDC17 ECUs - Opel EDC17C42 added from Nissan and Reanult solutions - Opel Marelli 75-90CV solution added new file type sign - Opel Z13DTJ improved - PCR2.1 solution added new DTCs - PCR2.1 solution added new DTCs - PCR2.1 solution improved for Golf 1.6TDI models. - Peugeot EDC16C34 solution improved for some models. - Peugeot DCM3.4 added in Citroen section - Peugeot DCM3.4 solution improved. - Peugeot DCM3.5 solution improved for other models. - Peugeot EDC15C2 different type signs added - Peugeot EDC15C2 some DTCs removing added - Peugeot EDC16C34 P2033 and P1461 DTC removing added - Peugeot EDC17C10 disable more DTC's about DPF additive system - Peugeot SID803 MPC solution has been improved. - Peugeot SID803A Generic improved. - Peugeot SID803A Generic item improved for Peugeot Expert2.0 models - Peugeot SID803A Generic solution improved - Peugeot SID803A Type new signs added - Peugout DCM3.4 improved for more compatible - Peugout SID803A generic added Boxer model signs - Peugout SID803A generic added Boxer model signs - PPDv1.x revized with new solution. - Protections improved, lots of trap points added. - PSA Delphi DCM3.5 added - PSA EDC15C2 bug fixed - PSA EDC16C0-7, EDC167C0-9 improved - PSA EDC17C09 - 10 bug fixed - PSA Group EDC15C2 Aditiv + Flap removing added - PSA SID803 MPC more improved - PSA SID807 item normal and EVO integration has been completed. - Range Rover EDC17CP11 added, improved. - Renault (Laguna) EDC16C3 solution revized - Renault and Nissan EDC17C42 solution added - Renault and Nissan EDC17C42 solution added - Renault DCM3.4 New DTCs automatic removing has been added - Renault Delphi DCM3.4 solution improved with new DTCs - Renault Delphi DCM34 solution has been improved - Renault EDC16C3 Type1 and Type2 DTC's optimized - Renault EDC16CP33 sign are improved. - Renault EDC16CP36 improved - Renault EDC17C11 Switch added, improved - Renault EDC17C42 improved - Renault EDC17C42 new automatic DTCs added. - Renault EDC17C42 P0294 DTC automatic removing added - Renault EDC17C42, Saab EDC16C39 solution signs are improved. - Renault SID305 new sign added - Renault SID305 P1525 and P2002 extra DTC removing codes added - Renault SID305 solution added - Renault SID305 solution improved for Laguna models. - Renault Type2 improved - Saab EDC16C39 bug fixed - Seat EDC17U01 Ibiza model ECU extra DTCs added - SID206 Generic added Galaxy model points - SID305 Nissan and Megane added - SID803 MPC DTC0000 problem has been fixed. - Siemens PPD1.x Flap removing has been added - Siemens PPD1x ECU's added New optimized solution - Skoda EDC17U01 switch solution added - Skoda SuperB EDC16U31 added - Subaru Denso added - Subaru Denso DTC calculation bug has been fixed - Suzuki DDIS optimized - Suzuki EDC16C39 solution improved - Suzuki EDC16C39 solution improved for other models. - Suzuki EDC16C8-10 solution has been improved. - Swedish Language has been added - Toyota Denso solution has been improved - Toyota Denso solution improved - Toyota EDC17CP07 improved for Yaris, Auris models - Toyoto Denso P2031 DTC added - Toyoto Denso P2031 DTC added - Treeview font 1 punto decreised. - Update EDC16-17 fast search section. - Vauxhall - Opel EDC17C59 solution improved - Volvo SID803 MPC DTC removing has been optimized for DPF relate only - Volvo EDC16C31 Switch solution DTC area optimized - Volvo EDC16C31 solution DTC removing has been improved - Volvo EDC16C34 Additive Control and Liquid DPF automatic removing added - Volvo EDC17CP22 + EGR + DTCs added - Volvo SID803 MPC solution improved - Volvo SID803A Revized - VAG EDC17C64 solution improved for other models. - VAG DCM37 solution DTC bug has been fixed. - VW - Porsche EDC17CP44 added - VW Amarok EDC17CP52 switch solution aded - VW Audi Q7 EDC17CP24 Switch added and improved for other models - VW Crafter added new signs for supporting to different soft versions. - VW EDC16C46 Passat Models P246e DTC automatic added - VW EDC17C64 switch solution has been added - VW EDC17CP14 solution improved for Golf6 models - VW EDC17CP14 Swirl Flap solution added - VW EDC17CP24 DPF Switch sign revized - VW EDC17CP46 DTC Root + DTCx80 removing added - VW EDC17CP52 menu bug fixed - VW EDC17CP54 Switch solution added - VW Group EDC17C46 new DTCs added Alfa : EDC16C39 Type1 and Type2 Audi : EDC16UX,EDC16CP3 / 34, EDC16U31, EDC17CP14, Siemens PPD v1.1, V1.2, V1.3, EDC17CP44,EDC17C46,EDC17CP04, EDC16C34-4 BMW : EDC16C31 - 35, EDC16C31 (1MB), EDC17CP02,EDC16CP35, EDC16C31New, EDC16C35,EDC17CP45 EDC17C41 Chrysler : EDC16CP31 Chevrolet : EDC16C39 Citroen : EDC15C2, EDC16C34, EDC17C10, SID807 Fiat : EDC16C39(Ducato), EDC16C39 JTD, MJD 6F3, 6F3 Doblo, EDC16C39 Generic, SID803A, Marelli 8F2, Marelli 8F3, Ford : EDC16C34,EDC16C34-2, EDC16C34-2.29, EDC16C34-5, SID 206, SID807, SID803MPC, SID803A, SID206(SMAX type), SID206 Kuga, EDC16C34 Picasso Type, EDC16C3-9.18 Lancia : EDC16C39 Honda : EDC16C31, EDC17CP06, EDC16C31(Advanced) Hyundai / KIA : EDC16C39-D373, KIA EDC16C39 Type2, Hyundai EDC16C39 Caren, EDC16C39 SantaFE, EDC17C08 Iveco : EDC16C39 Isuzu : Denso, Transtron DMax Jaguar : SID204, EDC17CP11 Jeep : EDC16U1, EDC16CP31, EDC17C49 LandRover : EDC16C39-Ford, SID208 Mazda : Denso 3-8 all series, EDC16C3,Denso CX7 Type with Adblue, EDC16C34 Mercedes : EDC16C31, Delphi DCM3.4, EDC16C31 Vito and Type2, EDC16CP36, EDC16C3, EDC16C31(2011+) EDC17CP10,M55 Error fixer Mini Cooper : EDC16C35 Mitsubishi : Denso (Full 2 types supported), EDC16CP39 Nissan : Denso,EDC16C36, EDC16CP33 Type1 and Type2, SID305 Opel-Vauxhall : Denso,Denso Signum,EDC16C39, EDC16C9, EDC17C18 - C19, Marelli MJET 75-90cv, Z16DT Marelli, Denso Signum, Z16DTC, Z19DT Peugeout : EDC16C34, EDC15C2, SID803 MPC,Delphi DCM3.5, SID803A, Delphi DCM3.4 Porsche : EDC17CP44 Range Rover : EDC17CP11 Renault : EDC16C3 Type1 and Type2,EDC16C32, SID305,EDC16C11 Saab : EDC16C39,EDC16C9 Skoda : EDC17CP14, PCR2.1, Octavia19 Bosch,EDC17U01,EDC17CP20,EDC16CP44,EDC17U01 Seat : Siemens PPD V1.2, PCR 2.1,, EDC17U01,EDC17CP20,EDC16CP44 Subaru : Denso Suzuki : EDC16C3 Type1 and Type2, EDC16C39 Toyota : EDC17CP07 Volvo : EDC16C31 Type1 and Type2,SID803MPC,EDC16C34, SID803A Type1 and Type2, EDC17CP22 VW : EDC16CP34, EDC16U31,,EDC17CP14, PCR2.1, EDC16CP34-4, EDC17U01,EDC17CP20,EDC16CP44 EDC17CP46,EDC17CP52,EDC17P24, EDC17CP44, EDC17CP54 All : EDC16 - EDC17 ECU's automatic DPF switch finder item * : Some EDC16 and all EDC17 ECU's solutions are using internal switches. --------------------------------------- Flap support list: -------------------------------------- Audi a4, a6 EDC16CP34 Toureg EDC16CP34-4 Jeep EDC16CP31 Audi EDC16C34 Alternate Audi V6TDI 3.0 Vectra C EDC EDC15VM P0098 (In EGR Remover) EDC16U1 Flap Solution EDC17CP04 EDC17CP14 ------------------------------------------------------------ Professional EGR Remover v2017.05.1 ------------------------------------------------------------ - Added these custom DTC removers : - Citroen - Peugeot EDC17C10 - Audi VW MED17.1 - Mercedes EDC17CP46 - Toyota EDC17CP07 - CP37 - Hyundai - KIA EDC16C39 - BMW EDC17CP45 - Mitsubishi EDC17CP15 - BMW EDC17CP35 - Fiat Marelli 8F3 - BMW EDC18CP09 - VAG EDC16C34 - Fiat EDC16C39 - Ford EDC17C10 - Iveco EDC17CP52 - Toyota EDC16C31 - EDC17CP04 - EDC17CP14 - EDC17CP20 - EDC17CP46 - EDC17C64 - MB EDC17CP10 - BMW EDC17CP02 - Alfa EDC16C8 - Honda EDC17CP06 - Renault Nissan SID305 - Peugeot - Citroen EDC16C34 -Fiat, Alfa ,Chevrolet EDC15C7 -PSA Group SID803a -Ford SID803 -Ford SID803a -Ford SID206 -PPDv1.x -Mercedes EDC16C31 -VW EDC16U1 series -EDC17CP14 custom DTC Removing internal BETA (next update will be added) -Still in progress : Delphi DCM3.5, DCM3.7 EGR, Opel Denso, (in development, tested) -Ford EDC16C34.2.30 total DTC -Alfa EDC16C39 total DTC -Audi EDC17C14 P2014 (Flap) -VM EDC15CVM P0098 (Flap) -Mercedes EDC16C31 DTC full table erase -Immo Generic EDC17 Solution. -------------------------------------------------------------- - 103 alternate signs added, increising file supporting - Alfa EDC16C39 Generic has been improved for other models. - Alfa EDC16C39 generic solution improved more - Alfa EDC16C39 generic solution improved more - Alfa EDC16C39 Solution1 added more sings for Alfa - Fiat - Lancai models - Alfa EDC16C8 has been more improved - Alfa EDC16C8 P0401 DTC automatic removing has been added - Alfa EDC17C49 EGR + DPF added - Alfa Guilette EDC16C39 special solution added in Type1 item - Audi - Skoda EDC15P solution added - Audi - VW EDC16U31 Generic revized, EDC16U34 ignored. - Audi - VW EDC17C46 solution improved with new DTCs - Audi - VW EDC17C46 Type4 solution added. - Audi - VW Marelli 4MV added Golf4 models supports. - Audi - VW ME7.5.10 solution improved and added on Audi cars support - Audi - VW PCR2.1 generic added new DTCs - Audi - VW PCR2.1 generic item support problems has been solved. - Audi A3 models EDC17C46 EGR hysteresis map problems has been fixed. - Audi EDC15VM+ solution now generic - Audi EDC16U31 Type1 solution revized - Audi EDC17CP14 Type2 solution added - BMW EDC15 Switch solution added - BMW EDC16C31 solution improved. - BMW EDC17C06 improved - BMW EDC16C31 custom DTC calculation bug fixed. - BMW EDC17C06 solution improved with new DTC removing - BMW EDC17CP02 added - BMW EDC17CP02 and EDC17C06 supported now, DTC's has been added - BMW EDC17CP02 EDC17CP06 solution problems are fixed. - BMW EDC17CP02 solution has been improved. - BMW EDC17CP06 improved - BMW EDC17CP06 revised. - BMW Mini EDC16 solution revized - Chrysler EDC15 EGR switch solution added - Chrysler EDC15 EGR switch solution added - Citroen - Peugeot EDC16CP39 added RuiSouza - Citroen - Peugeot SID803a Type2 new DTC's added. - Citroen - Peugout EDC16C34 EGR removing solution seperated - Citroen EDC15C3 3 new DTCs added. - Citroen EDC16C34 Berlingo signs added - Citroen EDC17C10 solution added - Citroen SID803A type custom DTC added in SID803 item - Custom DTC removing EDC17C46 Tiguan ECUs supports has been added. - EDC16U1 new type added, bug fixed. - EDC16U34 Generic Switch added, improved - EDC16U34 has been improved for other models. - EDC17 Immo section improved for other EDC17 ECU's - EDC17C46 - CP46 bug has been fixed. - EDC17C46 fixed for Passat and Alhambra models. - EDC17C46 Type overflow fixed. - EDC17CP04 solution improved - EDC17CP14 custom DTC removing improved for other models. - EDC17CP14 Solution1 P0401 DTC disabled added. - EDC17CP24 DPF signs conflict fixed - Fiat 8F3 improved for specially Ducato models - Fiat 8F3 solution P0409 and P0486 removing added - Fiat Bravo model added in Fiat Generic EDC16c39 item - Fiat Doblo solution improved - Fiat ducato type added - Fiat Marelli 8F2 and 8F3 EGR solution added - Fiat Marelli 8F3 solution added generic P0486, P0488,P0489 and P0409 DTC removing - Fiat SID803A added new DTCs for removing automatical - Fiat SID803A file id check has been removed, solution improved - Fiat,Alfa,Opel, Lancia, Citroen, Ducato,Hyundai,KIA,Saab EDC16C39 generic switch solution added - File control : CMD, Kess formats and blank file controlling added. - Flap EDC16C34 Generic improved for EDC16C34 softwares - Flap EDC16U31 P3103 added - Flap EDC16U34 solution2 DTC calculation added - Flap EDC17CP04 added - Flap EDC17CP14 some models bug fixed ( - Ford DCM3.5 improved for other models. - Ford Delphi DCM3.5 solution optimized, revised - Ford EDC16C34 Additive removing added - Ford EDC16C34 Focus models bug has been fixed - Ford EDC16C34 M.Patil Type ECU software solution has been added - Ford EDC16C34 signs are improved for different soft versions - Ford EDC16C34 some version support fixed - Ford EDC16C34 Switch solution added U0118 DTC disabled - Ford Sid 202 EGR Hyst. added - Ford SID202 P0489 DTC removing added - Ford SID204 added new DTC points - Ford SID206 Generic solution improved for other models. - Ford SID206 P0490 added - Ford SID206 P141a DTC conflict has been fixed. - Ford SID206 P246x DTCs added - Ford SID206 revized - Ford SID206 Type DTC's improved - Ford SID206 Type EGR Hystresis map problem solved. - Ford SID208 different size maps added - Ford SID208 has been improved - Ford SID208 improved - Ford SID208 more DTCs added - Ford SID208 optimized for Ranger and Transit model. - Ford Sid802 solusyon improved - Ford SID802 solution improved - Ford SID803 new 2 solusyon added - Ford SID803 P0490 disabled added - Ford SID803 P1412 DTC removing added - Ford SID803A added new DTCs - Ford SID803A optimized for Cmax model - Ford SID803A P2002 DTC removed problem fixed - Ford SID804 Type2 Solution added - Ford TDCI Delphi DCM32 Micro EGR removing solution has been added. - Ford Visteon 256kb type added - Ford Visteon DCU102 improved - Ford Visteon revized for also Peugeot - Hotstart Golf5 Type added new signs for different type maps - Hyundai / KIA solution totally revised. - Hyundai EDC15c7 added - Hyundai EDC16C39 Generic item added full KIA support - Improved dongle protection, added more data in dongle. - In Hyundai EDC16C39 switch solution important bug fixed - In PCR2.1 P246E DTC removing added. - Isuzu DMax Added (Aldo) - Isuzu Dmax improved with new file types - Italian language text has been revised - Italian Language totally revised, now more good - Iveco EDC16C39 EGR related DTCs automatic removing has been added - Iveco EDC16C39 revized - Jaguar Delphi DCM3.2 solution added - Jaguar SID204 solution added - Lancia 8F3 EGR removed added - Land Rover SID204 added - Land Rover SID204 bug fixed - Land Rover SID204 solution - Land Rover Visteon DCU solution added - Marelli IAW4MV solution has been added - Mazda Denso solution add signs for Mazda6 models. - Mazda EDC16C3-9 DTC's Improved - MB EDC15C6 Switch ve EGR MAP added - MB EDC16C31 1MB Type1 solution added new signs. - MB Vito solution added new sign - MB Y75 removing 512kb files bug fixed. - Mercedes B EGR Removing solution added - Mercedes DCM3.2 Micro solution added. - Mercedes DCM3.5 P0400 remove added - Mercedes Delphi DCM3.5 solution added - Mercedes Delphi DCM3.5 solution added new DTCs for removing - Mercedes EDC15C7 both solution added P1403 removing. - Mercedes EDC16 M55 fix section improved - Mercedes EDC16C02 solution more improved - Mercedes EDC16C31 - EDC16CP31 solution has been improved - Mercedes EDC16C31 1mb item now sum to in 1 one and improved. - Mercedes EDC16C31 customer DTC improved, added new signs - Mercedes EDC16C31 New models improved. - Mercedes EDC16C31 New section added some reported DTCs for other models - Mercedes EDC17C10 added - Mercedes EDC17CP10 more signs added. - Mercedes EDC17CP10 new sign added - Mercedes EDC17CP10 solution improved. - Mercedes EDC17CP11 new DTCs added - Mercedes Y75 solution new signs added - Mitsubishi Denso more DTCs added - Mitsubishi EDC16C31 solution has been added - Mitsubishi EDC16U31 added - Mitsubishi Pajero Denso EGR Removing added - Nissan Denso 1 mb and 1.5 mb file 2 solution added - Nissan Denso EGR removing has been improved - Nissan EDC16C3 added - Nissan EDC16C36 + DTCs added - Nissan EDC16CP42 EGR maps fixed - Nissan SID305 2nd P1525 DTC check - remove added - Opel Antara solution added in EDC16C39 Generic item - Opel Delco Hybrid Astra Type added - Opel Denso Astra models DTCs removing added - Opel Denso solution added. - Opel Denso solution more improved - Opel Denso solution more improved - Opel Denso Z17DTH type ECU solution has been added - Opel EDC16C39 DTC P2279 removing added - Opel EDC16C39 improved for Antara model. - Opel EDC16C39 revized switch solution - Opel EDC16C9 improved - Opel EDC16C9 new signs added - Opel EDC16C9 Signum model solution added - Opel EDC16C9 Type2 added new signs - Opel EDC16C9.23 solution new signs added - Opel EDC17C18 Added - Opel EDC17C46 Added - Opel EDC15C2 bug fixed - Opel Magneti Marelli 6f3 ECU DTC table supporting improved to all models. - Opel PSG16 sign problem has been fixed - Opel PSG16 solution added - Opel Signum3.0 Denso EGR solustion added - Opel Vectra 2.0 DTI EDC15C0 Old Model - Opel Vivaro EDC16C36 solusion revized - Opel Z13DTJ solution improved. - Packet file, encrpyted file detection added. - PCR2.1 Caddy type Egr Hysteresis map bug fixed - PCR2.1 Generic item added new soft version Golf6 file supports - PCR2.1 Generic solution important bug has been fixed - PCR2.1 Generic solution improved for Golf6 models ) - PCR2.1 generic solution maximum improved - PCR2.1 generic tuned file EGR remove problem has been fixed - PCR2.1 solution 8th map added new sign. - PCR21 Type3 signs improved to all types file - Peugeot - Renault Delphi DCM3.4 EGR removing has been added - Peugeot EDC15C2 different type signs added - Peugeot EDC16C34 Type1 P2143 DTC added - Peugeot EDC16C34 Type1 Revized - Peugeot EDC16CP39 P1445 DTC disable added - Peugeot SID803 MPC solution test byte removed - Peugeot Type1 solution P0405 DTC calculation added. - Peugeot EDC16c-7 EGR solution added. - Peugeout - Citroen EDC17CP10 Addive Pump removing added - Peugout SID801 solution has been added. - Polish language update to more good - Portuguese, Rumanian and Dutch languages some problems has been fixed. - PPD1.x EGROFF solution added - PPD1.x improved for Passat models. - Program security improved. Internal traps number now up to 289. - PSA SID803 MPC solution revized - Range Rover EDC17CP11 added, DTC's improved - Range Rover EDC17CP11 TDV6 model signs added - Range Rover SID204 DTC structures re-assembly for some models - Renault - Nissan EDC16CP33 added - Renault 1.5 CDI solustion added - Renault Delphi DCM3.4 solution added - Renault Delphi DDCR P1014 + EGR Map added - Renault EDC15C3 new signs added for EGR switches. - Renault EDC16C3-21.9 more DTCs removing added - Renault EDC16C3-9.21 added new solution for different type ECUs. - Renault EDC16C3-9.21 EGR map fill values has been set to 00 - Renault EDC16C3-9.21 revized, added full DTC's. - Renault EDC16C36 DF647 DTC removing added - Renault EDC16C36 re-improved for Injector detection problem - Renault EDC16c36 solution fixed, revized. - Renault EDC16C41 (Mascot) solution has been added - Renault EDC16C9 Full DTC removing added - Renault EDC16CP33 added - Renault EDC16CP33 improved, optimized - Renault SID305 solution added - RenaultEDC16C36 extra points added and improved - Saab EDC16C39 Remap item added P0400 DTC removing. - Saab EDC16C39 solution has been improved - SID803 MPC solution second P0409 DTC removing added - Siemens PPDv1.x Hotstart Fix added - Skoda EDC17C46 added - Skoda EDC17C46 added - Skoda EDC17U01 solution added - Smart EDC15 solution has been added - Smart EDC16C31 added. - Smart EDC16C31 Solution added - Suzuki EDC16C8 Solution2 bug has been fixed - Suzuki Vitara EDC16C3 revized - Swedish Language has been added - Toyota Denso Hilux solution has been added - Toyota Denso solution added - Toyota EDC16C31 solution has been improved - Treeview font size decreised 2 punto - Update period calculation bug has been fixed. - Vauxhall - Opel EDC17C59 solution improved - Volvo SID206 custom DTC removing support added. - Volvo SID803 MPC added - VAG EDC16U1 custom DTC calculation bug fixed. - VW - Audi EDC16U31 Type1 solution improved with new signs - VW - Audi EDC17C46 solution improved for different Audi models. - VW - Seat EDC16U34 Hotstart fix has been added - VW EDC16C34-4 Crafter solution added some new reported DTCs - VW EDC16U1 both DTC P401 added - VW EDC16U1 solution has been revised - VW EDC16U34 Caddy models P0407 removing added - VW EDC16U34 improved for Caddy models - VW EDC17C46 solution improved. - VW EDC17CP04 Solution added - VW EDC17CP52 menu bug fixed - VW ME7.5.10 ECUs EGR removing solution added (P0401 disabled) - When making Flap removing, was showing DPF removing message. All messages are fixed. Alfa : EDC16C39, EDC15C7,EDC16C8, EDC16C39 Generic Audi : EDC16U1, EDC16U31 Type1 and Typ2,EDC15VM+, EDC17CP14,PCR2.1,EDC16CP34,EDC17C46 BMW : EDC16C31 Type1 and Type2, EDC16CP35, EDC16CP35, EDC17CP02 Chrysler : EDC16CP31 Citroen : EDC16C39, EDC16C34, SID803A, EDC15C3, SID803, EDC17C10, EDC16CP39 Dodge : EDC16U31-4 Type1 and Type2 Fiat : EDC15C7, EDC16C39 Type1 and Type2, EDC16C8,Marelli MJ 70-75- 90CV,SID803A, Simos, Doblo Type Ford : EDC16C3-9, EDC16C34, Visteon, EDC16C9 Cmax Type, SID206, SID804 Honda : EDC16C31 Hyundai : EDC15C7 Lancia : EDC15C7, EDC16C39, EDC16C8,Marelli MJ 70-75-90CV,SID803A Land Rover : EDC16CP39, SID204 Iveco : EDC16C39 Isuzu : Transtron (DMax Type) Nissan : EDC16CP33,EDC16C3 Mazda : EDC16C34-2 Mercedes : EDC16C31 (1 and 2 mb types), EDC15C6 (Switch and Remap), EDC16C31 Type2,EDC16CP31 M55 Fixer, EDC17CP10, EDC16CP36 Mini Cooper : EDC16C35 Mitsubishi : EDC16U31 Opel & Vauxhall : EDC16C3,EDC16C39,EDC16C36,Marelli MJ 70-75-90CV, Z19DTH, Denso,EDC17C18,EDC17C46,Delco Peugeot : EDC16C34,EDC15C2,SID803A,EDC15C3, SID803,EDC16CP33, EDC16CP39 Range Rover : EDC17CP11 Renault : EDC16C3, EDC15C2,EDC16C3 Type2, EDC16CP36,Delphi DDCR Saab : EDC16C9 Seat : EDC16U1, EDC17CP14,PCR2.1,PPD1.x Skoda : EDC15VM+, EDC16U1, PCR2.1, PPD1.x,EDC17C46 Suzuki : Marelli MJ 70-75-90CV, EDC16C3 Volvo : EDC16, SID803, EDC17CP22 VW : EDC16U1, EDC17CP14, EDC17CP20, EDC16,PCR2.1, EDC16U34, EDC16CP34-4,PPD1.x,VW EDC17CP04 ----------------------------------- Hotstart ----------------------------------- EDC16C31, EDC16U1, EDC15, Siemens PPDv1.1 - v1.2 Special EDC15C2 - C3 switch finder ------------------------------------------------------------------ Professional Lambda Remover v2017.03 ------------------------------------------------------------------ - Audi ME7.5 - Audi ME7.5 support for other models has been improved - Audi MED17.1 P0420 CAT removing has been added - Audi Simos84 solution added - BMW MSD80 CAT removed solution added - Ford Focus ME9.0C Lambda + O2 solution added - Ford ME9.0c P0038 DTC removing added - Ford ME9.0c P0038 DTC removing added - GUI improved and languages added - Honda ME7.9.2 Lambda removing has been added - Maserati CAT OFF solution added - ME7.5 Lambda solution added - MED 7.5.11 P1070 removing added - Mercedes ME2.8 solution improved for different MB models. - Nox MED9.5.10 improved - Nox MED9.5.10 improved - Nox, O2 and CAT solutions added. - Octavia Simos 7.1A CAT - O2 removing added - Opel Corsa ME7.6.1 O2 solution added - Peugeot IAW48P O2 - CAT removing solution added - Program coded from starting, more fast and solutions more improved - PSA ME7.4.4 has been improved. - Saab Tronic 7 and 8 CAT removing added - Seat Marelli 4Mx CAT removing has been added - Seat Marelli 4Mx CAT removing has been added - Skoda MED9.5.10 - Smart ME7.7.0 solution added - Solutions included automatic DTC calculations for 0 error. - Suzuki Swift Denso CAT removing added - Swedish Language has been added - Toyota ME7.9.2 CAT removing added - Toyota ME7.9.52 signs added - Toyota ME7.9.52 signs added - Volvo Turbo Series M4.1.1 Lambda - CAT remove solution added - Volvo Turbo Series M4.1.1 Lambda - CAT remove solution added - VW Bettle Simos33 Lambda solution added - VW MED9.1 CAT improved - VW MED9.1 CAT improved - VW MED9.1 O2 - CAT removing added Alfa : ME7.3.1, ME7.3H4, ME7.9.10, MED9.5.10 Audi : ME7.1, MED9.1.1, MED9.5.10 BMW : ME9 Chrysler : ME2.8 Citroen : ME7.4.4, ME7.4.5, ME7.4.6 Dodge : ME2.8 Fiat : ME7.3H4, ME7.9.10 Ford : ME7.9 Jeep : ME2.8 Lancia : ME7.3H4 Mercedes : ME2.8, ME2.8.1 Opel : ME1.5.5, ME7.6.2 Peugout : ME7.4.4, ME7.4.5, ME7.4.6 Seat : ME7.7.10 Skoda : ME7.1 Volvo : ME7.0 XEP VW : ME7.1, ME7.5.10, MED9.1 BMW ME9
2 minuti fa, Dany88 ha scritto:
apparte questo,qui sul forum su quella ecu trovi qualsiasi info,l'eliminazione dal controllo è un solo bit!
Grazie, appena la leggo e la modifico posto tutto. E' da un pò che non metto mano sulle auto. Oggi un amico mi ha sollevato il problema e mi sto attivando per risolverlo rispolverando il caro vecchio mpps.
Ospite
Questa discussione è chiusa.
