7 minutes ago, customobd said:
no works, necesary bdm full
sorry for english
no problem for your English !! what problem you have you? issue with immo ? If so you write the flash that I posted is posted on the EPROM files that I do for you syncro
ok friend then you need a flash golds for that type of ecu !! the only one that I posted is that other users have to wait for a new correct flash
that file that I have already sent to you is already virgin ( syncro ) !! to start the car needs full bdm flash is for the ECU
