Seat Ibiza TDI 1.9 101cv
Hi
I am new around here.
I can undestand a bit of italian, as i am portuguese.
I prefeer to write in english because i cannot do it in your language properly, so i hope that is not an inconvenient to you.
I own a Ibiza that started to smoke a lot and with strange vibreation and lack of power between 1500 and 2100 at high throtle load...
I did read the ECU and tryed to modify it a bit, and now seems a bit better, but not quite good... Maybe it is some sensor that is giving wrong info, or something like that.
As i am new at this remapping thing and i know here are some of the best remapers around, please take a look at my .ori file to check if there is some thing bad with it and i send you also two of my mods to that car... please comment it and let me know if i am too way wrong with it, and aproximately how many extra hp it gives in each one (if it really is effective)
Other doubt i have is that as i've seen, there is always more than one map in each car... Wich one is to modify? For example for ibiza, there are 6 injection maps... Why?
well... I am learning , and i dont believe it is so simple as putting more diesel and more turbo , to have more power... i belive that it is a bit like that , but in exact dosis and with more parameters regulated also...
Please, dont forget to comment my mods.
(I Will send in a reply to this tread, as i dont think i can send tho at once...
Best regards
Yoseff
I suggest you to try to replace the MAF, the symptoms you described (like the lack in power) may indicate your MAF is gone...
Ciao !
