mia prima mappa
Hello. This is my first mappa. It is of the Vectra B 2000 16v Y20DTH year 2001 and Ecu 0281010269. What do you think? Thanks for all.
Regards
VectraB.rar
Sono due file totalmente diversi!
Ori 17 ott 2006
Mod 25 gen 2008
Se impieghi 2 anni per rimappare un file stai fresco!!! :wink::roll::lol:
jajaja no Tuning Inside. This ecu can't be read then they sent the original and it has this date
Tuning can you help me? Are maps modified well? What maps apart of these, should i modify?
Come faccio a vedere le mod ke hai fatto se i file sono diversi?Trova ori e mod uguali e poi ne parliamo.
I am sorry, how can it be it? The mod I have extracted it of the ori modifying the values with ecm2001
I'm sorry, but I don't understand you. This is the problem of the languages
you must attach two files.. original ad modified
the original and modified MUST BE quite the same file.. with few difference ONLY at important addresses....
you understand?
yes yes, if it is that I have done. This original I have modified with the ecm. I have modified:
- Iniezione parzializzato: +7 % to 700rpm from 10 to 100 of load and +8 % from 800 to 3700 rpm from 10 to 100 of load.
- Iniezione correzione: +6 % to 1000 rpm from 60 to 100 of load and +7 % of 1200 to 3700rpm from 60 to 100 of load
- Limitatore di coppia: +20 % maximum
- Overboost: +8 % all the map.
And with these changes the ecm has made to me this mod. If I compare the ori with the mod I see that the files are equal except the directions of the modified maps, so I'm sorry but don't understand which is the problem.
I will upload the files again by if I uploaded badly
Vectra B ori+mod.rar
Hello again. I have realized what you were saying Tuning Inside. I have seen that there are modifications at the end of the file, but not why it is modified. I have seen that when I change a value of a map, the ecm modifies me the end of the file automatically he alone. Why does this happen? How do I can solve it? Thanks your very much for all
Regards
The mod file that I uploaded, I put it in the car and now I have seen that he has changed the number of frame. How can I restore it?
Regards
Hello, my new remap is this. To see I have managed to solve that you were saying to me and to see that it looks like to you the modifications. Give me your opinion please. Thanks for all.
Regards
per favore mi controllate questa mappa? Grazie
Ospite numeridacirco
for your sodisfaction, you can to use it!
after you can tell us your impression!
hello, I have proved it in my car and I am satisfied but I would like to know if I can improve something more to the map.
Regards
