Vw Golf 4 1.4 16V De 2000 Non Si Avvia! Help!
Ospite pepito
buongiorno a tutti,
ecco le mie preoccupazioni: un golf 4 di 2000 Ecu Ecu 036906014AN61600.497.01 IAW4CV.V0, avviasi e taglia immediatamente!!
l'automobile è partita da VW, hanno cambiato il contatore, il barilotto e riprogrammato le chiavi ma sempre niente, non si avvia!
annunciano solamente bisogna cambiare l'Ecu.
Ho ricuperato l'automobile fiat una diagnosi con vag com :
Address 01: Engine Labels: 036-906-014-AHW.lbl
Part No: 036 906 014 AN
Component: MARELLI 4CV 2893
Coding: 00031
Shop #: WSC 01317
VCID: 5CB39043E30F
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 01317
VCID: 3E773ACB1553
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 02 AIRBAG VW5 0003
Coding: 12338
Shop #: WSC 01317
VCID: 356525E72065
1 Fault Found:
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 821 X
Component: KOMBI+WEGFAHRS. BNO V27
Coding: 00141
Shop #: WSC 01903
VCID: 397D29D70C7D
Subsystem 1 - Part No: Ident
Component: Nr. WEGFAHRS.:VWZ6Z0X1420399
Ident.-Nr. WEGFAHRS.:VWZ6Z0X1420399
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01903
VCID: F0EB54F39F87
3 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01316 - ABS Control Module
01321 - Control Module for Airbags (J234)
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 4E Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 01317
VCID: 84030823BB3F
Subsystem 1 - Part No: 1J1959801C
Component: 4E Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 4E Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 4E Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 4E Tõrsteuerger. HR0002r
1 Fault Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
End ---------------------------------------------------------------------"
C'è bene un problema di immo ma il vedente non è acceso.
Ho verificato i fusibili, relè, alimentazione Ecu, massa...
tutto è corretto!!
auguro acquistare un Ecu di opportunità con l'immo disattivato per fare un test dunque o se avete un'altra idea?
Se avete una soluzione sono acquirente
grazie
grazie per il link
caricare la batteria
e cambiare le batterie nella chiave telecomando
Ti farò sapere
