mclaudio Inviato 10 Luglio 2012 Inviato 10 Luglio 2012 Hello anybody can help? how can i disable EGR in fiat Linea 1.3 Multijet 90? i have mpps cable also...one friend of mine with grand punto 1.3 multijet 90 has already remaped ECU. can i just copy its ECU remap and apply on linea? regards
max37 Inviato 10 Luglio 2012 Inviato 10 Luglio 2012 Mail ECU data The original file is 2mb mpps writes only 1mb You can read the file with original BDM ECU, or put the data and look for the original 2mb files .. egr is easy to close after the cuts and write files with 1mb mpps
mclaudio Inviato 10 Luglio 2012 Autore Inviato 10 Luglio 2012 hello. can you check your private message? i have answered. please please help
mclaudio Inviato 16 Luglio 2012 Autore Inviato 16 Luglio 2012 if i read original file, then reflash the original with mmps will it be blocked?
