Aiuto per pinout
Ospite PSOP44
Salve a tutti, qualcuno ha il pinout di questa ecu? L'ecu è di una ford focus 1.6 benzina del 2001. Grazie.
Ospite rialelettronic
cosa te ne fai del pin out non c' è sistema di programmazione che non debba passare per il modulo siemens
anche il powergate non comunica se non per la presa obd
comunque la rete offre questo
Pin number function color
1 shift solenoid - B gn/bu
2 not used
3 IMRC module signal wh/rd
4 Transmission range sensor - reverse gn/bu
5 not used
6 not used
7 transmission range sensor - 1st / EVAP vent valve gn/wh - bk/og
8 transmission range sensor - 2nd gn/og
9 Barometric absolute pressure sensor wh/bk
10 not used
11 transmission range sensor - drive gn/bk
12 switched ground bk/wh
13 Flassh EEPROM power supply og/bk
14 not used
15 SCP - bu/bk
16 SCP + gy/og
17 switched ground bk/wh
18 not used
19 TX signal gy/og
20 Injector 3 control bk/bu
21 crankshaft position sensor + wh/rd
22 crankshaft position sensor - bn/rd
23 ground bk/ye
24 ground bk/ye
25 ground bk
26 switched ground CDA (coil 1-) bk/og
27 start inhibit relay circuit bk/rd
28 vehicle speed signal output wh/vt
29 overdrive cancel switch input gn/bk
30 not used
31 Power steering pressure sw input / press. sensor bk/yel / wht/vt
32 sensor return (refrence/ground) bn/ye
33 Output shaft speed sensor - bn/bu
34 turbine speed sensor + wh/vt
35 HO2S 2 signal wh/rd
36 MAF return bn/bu
37 transmission fluid temp + wh/gn
38 cylander head temp / coolent temp sensor wht/vt / wh
39 MAF input wh/vt
40 fuel pump monitor gn/bk
41 A/C clutch pressure cycling switch input gn/ye
42 PATS indicator control bk/og
43 sensor signal wh/bu
44 Pressure control solenoid A + gn/og
45 Camshaft timing actuator control bk/rd
46 Low fuel indicator bk/wh
47 electronic vacuum regulator solenoid valve control bk/gn
48 not used
49 CAN bus L bu/rd
50 CAN bus H gy/rd
51 ground bk/ye
52 switched ground CDB bk/gn
53 RX signal wh/gn
54 fuel pump output / switched ground bk/wh - bk/bu
55 hot at all times rd
56 EVAP purge valve control bk/bu
57 Knock sensor + wh/bk
58 VSS / OSS + wh/bu - wh/bu
59 generator monitor circuit gy
60 HO2S 1 signal wh
61 not used
62 fuel tank pressure transducer sensor signal wt/vt
63 fuel rail pressure transducer sensor signal wh/gn
64 transmission range sensor P/N / clutch switch grn/yel / wht
65 exhaust pressure transducer signal wh/bu
66 not used
67 EVAP canister vent control bk/og
68 switched ground bk/bu
69 switched ground bk/ye
70 injector 1 control bk/wh
71 power hold realy output (VPWR) gn/ye
72 generator communicator command lb
73 shift solenoid - A / check fuel cap light grn/yel / blk/wht
74 not used
75 gnd (power return) bk/wh
76 turbine speed sensor - / signal return / sig rtn bn - wh/vt - bn/wh
77 power ground bk/ye
78 not used
79 not used
80 IMRC control bk/wh
81 pressure control solenoid A- bk/rd
82 Shift solenoid C gn/bk
83 idle air control valve control grn/yel
84 not used
85 camshaft position sensor signal / sensor sig rtn wh/vt - bn/wh
86 sensor signal wh/rd
87 knock sensor - bn/ye
88 MAF output wh/bu
89 throttle position sensor signal wh
90 VREF ye
91 transmission fluid temp - bn
92 stop lamp switch input gn/rd
93 HO2S 1 control bk/ye
94 not used
95 injector 4 control bk/og
96 injector 2 control bk/ye
97 power hold realy output gn/ye
98 not used
99 shift solenoid D gn/og
100 HO2S 2 control bk/bu
101 not used
102 shift solenoid E gn/wh
103 ground bk/ye
104 not used
oppure vai qua:
http://www.fordfuelinjection.com/
Ospite PSOP44
Grazie ria, allora c'è un modo per leggere/scrivere questa ecu? L?eprom è integrata nel micro.
Ospite P T motorsport
si fa da obd senza problemi
Ospite PSOP44
del 2001 in linea can? E' possibile farla al banco conoscendo il pinout?
